Years ago I removed the IHC magneto from my 1952 TD 6 , which starts on gasoline, and installed a distributor with solid state ignition. Still have the magneto as a back up. I think to time the magneto to the engine I did the following: brought the engine up to TDC on the compression stroke, turned the magneto from the coupling CCW until the rotor was pointing at number one cylinder. Installed the magneto on the engine at this point.
Is this correct? I didn't turn it through impulse for number one cylinder
