Brakes R and R 1948 TD 6
ejensen
I wanted to know if it was necessary to remove the pivot lever to replace and remove the 3 piece brakes on my 1948 TD 6. Found a tractor wrecking yard that has people familiar with the older TD 6 crawlers. It is not necessary to remove the pivot lever to remove and install the brakes. Not all of the people at the place have the knowledge. One person I talked to told me he has done many brake jobs on the older TD 6 crawlers.
Found the answer to my question regarding if it is necessary to remove pivot lever to replace and remove brakes on a 1948 TD6.
According to information I have obtained from FT. Smith Equipment in California, it is not necessary to remove the pivot lever. Not all people at Ft. Smith have working knowledge of the older TD 6 crawlers. I was fortunate enough to talk to someone who had worked on the older TD 6 crawlers.
