Mr. T. Minnesota
Forum,
Just changed oil on an old Pettibone skidder with Ford industrial diesel engine. Oil is 15-40 Delvac oil and it pegs the gauge at about 80 psi cold, idle it is about 40 psi. Should I wait for it to warm up before getting concerned.
Second question, has a front mount hydraulic pump and I need to change the generator belt but belt goes around the front mount pump shaft. What is the preferred method to change belt? Looks like the shaft could be dismantled from crank shaft pulley?? Any and all thoughts welcome!
Mr. T. Minnesota
Mr. T. Minnesota
