Brakes are three piece type. Had to remove the back brake through the bottom brake inspection place and cut it in pieces with a sawsall to remove it. It was stretches and bent. Brake drum good condition. Other two sections came out the top through the top brake inspection hole.
Does anyone know if it is necessary to remove the brake lever in order to install the brakes? I do not know if the brakes would be installed from the top or through the brake inspection area bottom of crawler. Does anyone know of places that do repair work on the older TD 6 crawlers? Would like to contact someone for advice on installing the brakes. Got new brakes from General Gear in Idaho
