Case 350 Bull Dozer
Having problems with the track on the left hand side locking up
When I move a 2 feet or less on flat ground it will
Lock up . It will not lock up god no backwards
I just had the coil spring replaced
On right side . on the left side
Tension adjuster replaced
Thank you so much for help
Was it tracking ok before the recoil spring was fitted,have the brake checked,if still not right drain the final drive oil for that side and see if there is any metal in it.
AJ
(quoted from post at 14:47:46 03/25/17) Was it tracking ok before the recoil spring was fitted,have the brake checked,if still not right drain the final drive oil for that side and see if there is any metal in it.
AJ
How do I check the breaks
It tracks moved before the
Work that was done
You should get the person that fitted the parts to look at it,the only thing I can think of is the track too tight or is the master pin not driven home and is getting caught in the frame.
AJ
