2010, engine alternatives?
trak
have a 2010 crawler loader, engine needs the sleeve rack.. think this is referred to as the 145 engine... would there be an alternative john deere engine that could be used in this crawler?
Deere 45 combine engines:
145 Power Unit
165 Power Unit
155 Power Unit
165 Power Unit
HA217 power unit
HA-155D sleeveless engine used in 45 combine
HB-145L
HB-145G
TA-145G
TA-145L
HA-165D - diesel used in 45 combine - ser # 45-2996 - 45-46000)
HA-165G - gas used in 45 combine - ser # 45-35001 - 45-46000
HB-165D - diesel used in 40 combine
HB-165G - gas used in 111 peanut combine
I have a running power 4 cylinder power unit from a baler. I think it would work. Located southwest Indiana. If interested I could check the numbers tomorrow. Have changed the rear over to clutch with bell housing .
FYI some of those power plants were the same engine used in the 1010 tractors, my 2010 backhoe had one which I did not know until I pulled it apart the pistons are smaller than the 2010, so less power..I was not to concerned because it ran the hydraulics, but lacked when using the loader. Not to sure I'd want one in a dozer though..
I currently have a gas engine ,, pretty sure it came from a 2010 tractor,, it doesn't have enough power for the loader, ready to switch back to diesel if possible. thanx
