CASE/ TERRATRAC 320 CRAWLER RESTORATION
RJZAMISKA
PRESENTLY TEARING DOWN A CASE/ TERRATRAC 320 CRAWLER TRACTOR. WORKING TO GET ESTIMATE FOR RESTORATION. PRESENTLY ASKING IF ANYONE KNOWS OF ENGINE REBUILDERS OR WHERE TO GET ESTIMATE FOR A SHORT OR LONG BLOCK FOR A CONTIENTIAL G148CID GAS MOTOR IN THE NORTHWEST PENNSYLVANIA, NORTHEAST OHIO AREA. THANKS RAY.Z.
BASED ON MY INFO THAT I HAVE SO FAR ITS A 320, SER.#4948, VALVE BLOCK HAS G1148 CAST ON THE TOP FRONT LEFT SIDE. DOING A HISTORY SEARCH THAT PART I WAS NOT SURE OF CASE OR OTHER, SO YOU BELIEVE ITS A CASE MOTOR??? THANKS FOR REPLY. RAY.Z.
a pic of it will tell the tale,, Case engine has a LH side carburetor, the Cont engine is ont he RH side this while sitting in the seat facing forward
CARBURATOR IS ON THE LEFT HAND SIDE ALONG WITH THE GENERATOR AND VOLTAGE REGULATOR WHILE SITTING IN THE TRACTOR, STARTER, DISTRIBUTOR AND OIL FILTER ASSEMBLY IS ON THE RIGHT. THAT BEING SAID, IS THERE A DESCRIPTIVE NAME FOR THE MOTOR OR SOME OTHER NAME OF CALLING THE MOTOR. THANKS RAY.Z.
sounds like a Case power plant,, I did further checking and it seems the book I was getting that data from is incomplete,, the later 320's have the Case built 148G gas engine sorry for the confusion
cnt
NO TROUBLE AT ALL, I LOOK FORWARD TO ANY DISCUSSION TO HELP ME UNDERSTAND THE DOZER . MY NEXT QUESTION WOULD BE IN TEARING THE THING DOWN I'M IN NEED OF A MANUAL TO TELL ME CLEARANCES (BACKLASH) AND OTHER. DO HAVE A PARTS MANUAL BUT NEED SOMETHING ELSE. ANY SUGGESTIONS. THANK YOU FOR THE REPLIES. RAY.Z.
a 310 Case crawler service manual will give you all those specs you are looking for and if nothing else can still be bought from Case, I would check this site as they may have one available as well
cnt
