International 100
Lonsomepine
New User
My track loader just quit turning right. It was my grandfather's I know it's a 80's. The main brake also has no pressure and isn't working. The left brake works fine.
100 things but it is all going to be in the right side drive. Most likely the steering clutch has failed but it may be as simple as a pin coming out of the rod that works the steering clutch. You start at the pedal and work your way back to the steering housing there under seat. They were bad to have steering clutch problems.
