JCB backhoe id help
Hello need help with a JCB 17BT4086/321969/7 .Would like to find out if it is a 1400B center mount ,1400B side shift ,site master 1550B ,1600B , 1700B . Any help would be great . Thanks for the help.
Does the cab door slide or open out,if its a side shift it will have a H frame on the back with the jack legs vertical,if its a center pivot the swing tower is in the center,there is no H frame and the jacks are at an angle,is the powertrain manual or does it have a shuttle,post a picture of it.
AJ
I think,it's 1986 1700B, I cannot tell if it's a sideshift or center pivot from the numbers,if its a sitemaster it will be fitted with a four in one bucket with forks attached and piped for a rock breaker.
AJ
