gabsgrammy
I recently replaced the head and head gasket on my Case 1840 uniloader with the 4BT Cummins engine. Now I need to put diesel lines back on injectors and bleed the system. The manual fuel pump on this model seems to have a metal tang instead of a button to pressurize fuel system. My questions are: do I bleed the two bleed screws on the injection pump; the the two fittings (one with "banjo" fitting ) by the fuel filter, then finally bleed the four injectors, one at a time? Moving the metal tang up and down on what I believe is the manual fuel pump doesn't seem to be building up ant pressure...please, any nd all advice is needed and appreciated.
