JD 210c alternator wiring diagram
ConradB
New User
Have a JD 210c 4x4 and the alternator bit the dust. Got a Bosch type 95 amp replacement unit, but the wiring is connected differently than it is on the existing dead unit.
Any wiring diagrams available for it? My JD shop manual doesn't give a color code, but makes reference to Section 9510 Group 05 which I don't have.
Thanks in advance for any help!
Usually the Bosch alternators have three connections,the + or Bat, D & W,as I don't know what colors the wire are on your JD,the battery cable goes to the biggest terminal marked + or Bat,the wire for the dash light or buzzer can be found by switching on the key and ground the wire the buzzer or dash light will come on,the other wire goes to the W terminal for the techo.
Good luck
AJ
