1969 Case 580CK Backhoe Clutch
rasman57
My 69 580 Construction King Backhoe tractor Sat for about a month after using it. Now I can not get the clutch to release...pedal feels normal with good sing resistance but can't get the tractor to go into gear forward or reverse by use of the mechanical shuttle. Trans and shuttle will allow me to start the tractor in gear and go but pushing the clutch in doesn't take it out of gear. Any suggestions on how to determine if the clutch is stuck versus failed parts?
More than likely the friction plate is stuck to the flywheel,to break it free put the tractor in the highest gear in forward or reverse,hold the clutch pedal down tight,all brakes on tight and hit the starter button,if it does not break free tighten up the clutch till there is no play and try again,if it brakes free readjust the clutch.
Good Luck
AJ
