I am having trouble with my radiator. When I run the tractor just a few minutes the radiator starts to over flow through the spout on the fill neck. should there be an overflow tank on this machine? I have washed the radiator and put a new cap on it. Washing seemed to help, but the antifreeze still spills out. Any ideas? I am trying to eliminate everything before I have to pull the radiator. Thanks in advance.
Excuse my ignorance, but is it possible to have a bad head gasket without getting water in the oil? or oil in the radiator? I check both before I start the machine, and both oil and water are just as the should be, no foaming in water or milky oil.
