caterpillar guy
I need the pulley for both the crank and the fan. The V-grooves are worn out. The Fan part number is a 9L643 if there is anymore to it they drilled it out with the balance holes. The last digit could be a 3-6-8-9 not sure of that one as most of it was drilled away. You can see what looks to be a curved number on the bottom half.
I also need the crank pulley for this.
SN# 69D2988
AR# 4N5470
The engine Modification Number is 5N1207-00
Model # 1673C
This engine is in a Stieger cougar I ST270 would be the HP on it.
I did not want to go to Cat for them. Also if it is not in a truck or one of their pieces of equipment they don't want to help you with it. At least that is the case in MI
SN# 69D2988
AR# 4N5470
Model # 1673C
