Case 450 removing small lift cly on crawler loader
So I don't kill myself it looks like if I tilt the bucket teeth in the ground it extends the cly about 3 inches should be able to swing out the way to pull ram this right
Yes you can do it that way Just remember the hydro-leveling cylinder is tied into the bucket dump circuit so when you unhook the hoses or even the pin the bucket Can move make sure you set it and isolate it so it cannot get you in a bind
cnt
