cat engine pulleys
caterpillar guy
I need the pulley for both the crank and the fan. The V-grooves are worn out. The Fan part number is a 9L643 if there is anymore to it they drilled it out with the balance holes. The last digit could be a 3-6-8-9 not sure of that one as most of it was drilled away. You can see what looks to be a curved number on the bottom half.
I also need the crank pulley for this.
SN# 69D2988
AR# 4N5470
The engine Modification Number is 5N1207-00
Model # 1673C
This engine is in a Stieger cougar I ST270 would be the HP on it.
I did not want to go to Cat for them. Also if it is not in a truck or one of their pieces of equipment they don't want to help you with it. At least that is the case in MI
If you've got part numbers, give Offroad Equipment Parts in Tennessee a call. They deal in both NOS CAT parts, as well as aftermarket parts , all at prices far lower than CAT proper.
Offroad Equipment
