Diesel Tch:No model # on the tag but the ser.#is20906 RP if that helps. Set # isSR63/900/3/2130. I bypassed every thing on the engine and I am injecting clean filtered diesel directly into the pump via electric fuel pump; 5-9psi. The first time at the D shop the clerk said it barely made the spec pressure because the barrel had some rust and had to be sanded clean. It didn't start so I had him install a new barrel, pressure exceeds specs. After a year I started working on the machine again.To be on the safe side is the top lever the fuel shut off or is it the bottom lever. Nobody around here has a 6 cyl Perkins. Thanks Udo
