Cannot seem to find too much help elsewhere so going to see what I can find here.
We have an old 225 that we bought several years ago. We literally don't track it around and has really just been used to pick things up to put in trucks such as brush.
Back when we bought it, one of the track drive motors was loose, it was on the list for repair while thinking "who would do that?".... Anyway, I guess we forgot about it because the machine does not go anywhere.
Now we need it at full capacity and yesterday. Tried to track it and that track keeps stalling like it is getting in a bind. Tracks are not the best but verified the pitch does not exceed book spec and I tend to think the issue might be in the gearbox.
We thought it was the track brake because it was leaking bad into the final. I found the air breather on the top knocked off and water got in there, friction discs were toast, both springs were broke, input shaft was cracked from drive motor hanging on it (loose), and input bearing really toast.
I fixed all that really thinking that input bearing was my issue. Nope, still doing it.... I can creep along very slow and it seems ok but you know when you start going too fast and things start binding. There are no crazy noises, just the track stops and the engine loads up responding to the bind up.
The finals on these are linear, not planitary. Built pretty rugged. When I drained final oil, it was watered down for sure with pure water at the bottom, then the milky fun stuff. No steel chunks at all. However, looking in to see what I could, I did not see much corrosion in there and gears looked mint. Limited air exposure I guess....
I cannot be sure if what what might be hurt in the final or how to check. Looks like there are about 4 reduction gears with tapered roller bearings on each of the shafts. I am simply not sure if a bearing is damaged causing gear lash issues or what, or even how sensitive it might to a little play.
Confirmation of final issues is going to be a bad day. That will really suck to repair. These require the ENTIRE final removed from the carbody just to get the cover off, not to mention all the fun tools required for the job. I can get a few of the bearing covers off one side where I could possibly inspect things.
