Cat D8H 35A fuel torque converter
MKangas
New User
Gentlemen, Ladies would there be any chance someone would have a contact that may be able to help me find a 35A fuel torque seals etc. Most parts are discontinued and I am running into a wall. I have contacted the ACMOC and am hopefully awaiting a response. Thank you in advance.
Matti
2x 5H4904 seal
2x 5H4909 seal
4x 5H4764 gasket
2x 5H4763 gasket
2x 6H8324 gasket
2x 6H8325 washer
4x 5H4975 washer
4x 5H4908 ring
1x 5H4973 yoke
2x 5H4906 ring
2x 6H1304 svc Gp
2x 8H5626 seal
4x 5H4903 seal assy
I can only source about 3-4 parts.
Thank you.
go to machinery trader parts search and plug those numbers in---you should get quite a few hits---i also use google search quite often with part numbers
I talked to Jesse at Off Road Equipment Parts Mon morning. He looked everything up for me and was able to get the following pieces. If I remember right, there was at least one used item, which I believe was the 5H4973 yoke, but the rest were all new CAT, or aftermarket.
2x 5H4904 seal
2x 5H4909 seal
2x 5H4763 gasket
4x 5H4975 washer
4x 5H4908 ring-----can only find one
1x 5H4973 yoke-----used
Their number is 1-888-379-7895. Like I said earlier, talk to Jesse. I told him I would pass on the info, and asked him to keep a copy of the items on hand in case you called.
For some of the other seals you can't find, you might try calling your local CAT and see if they maybe changed part numbers. I've seen that cause problems, even with a dealer, if the parts guy doesn't know what he's doing.
Beyond that, measure the seals and find some to match from your local bearing house. Most items like that are common, but, like many other OEM's, CAT likes to put their part numbers on them just to make them harder to find without going back to the dealership.
Good luck.
Sure do not want to rain on your parade but years ago had a lot of experience on those. The seals you are replacing are only case seals. IF you have leaks out the yoke chances are the internals are worn and it is bypassing. At best the fuel torques were meager , I guess that is why cat did not use them long. Hope you find your seals but thinking you need to take it all the way down and check it all out.
