TD15c. Help learning for new member
GospelTed
New User
We bought a td15c dozer and was told everything worked a year ago but now it doesn't have power to push dirt. Could there be a filter that I could clean that would affect the torque converter?
It seems like everything else is in good condition. Starts every time. I found a rebuilt converter for $3900. But just want to know if the one that's in it can be checked, serviced? Please call if you can 724-288-6982, thanks
Hey jm
I'm curious about you might be the fellow who bought a Small
Dozer from me close to St Louis 7-8 years ago?
Was a International TD8E.
Just wondering the gent was from Tenn. can't remember what part and you seem to know a lot about dozers.
Tom
(quoted from post at 18:19:29 08/29/16) Ted I tried to give you a call but no answer.. My e mail is open... jm.
Hello we own 2 TD 15 c 250c dozers only one is operational. We are having a problem with the steering now it can only turn to the left we did the major adjustment for the hand lever last fall and now it does not want to turn again. We tried to put the blade down and only the one track turns. With the winch off can't see any visible problems. Any advise would be greatly appreciated Thank You.
Same thing e-mail me a phone number and I can have you going in 30 minutes, but too much to type and I have to make sure you understand exactly what to adjust or you will mess it up. All you do is send it thru the board here and I will call you
(quoted from post at 14:20:07 08/30/16) Same thing e-mail me a phone number and I can have you going in 30 minutes, but too much to type and I have to make sure you understand exactly what to adjust or you will mess it up. All you do is send it thru the board here and I will call you
(907) 432-2253
(quoted from post at 16:21:15 08/30/16) You got it buy about any ih dozers I can find..
So I'm to decipher you did buy my TD8E ?
You still have it or flipped it?
Curious I miss that old girl.
She was a good machine.
Tom P
Sorry I missed the call, I will keep a closer watch on my phone, sometimes I am in bad cell coverage. 724-288-6982
no this is my first shot at owning a dozer and its a td15c, never had another dozer. trying to get the charge pump to work for the torque converter, call if you have any advice, 724-288-6982
(quoted from post at 16:53:04 08/30/16)
(907) 432-2253
ello again the serial # on our TD15 dresser is 273-19 E00002630 we could not find the adjustment that you were talking about. The newer one we are running is a Kamatsu and the older one we have is a international but have interchangeable parts so we have been using the older one for parts. We already changed the sprocket on the right side hoping we don't have to that again on the left now.
If you still have my number give me a call again, I have trouble getting thru to you. I AM CERTAIN I can make it steer.. Just takes a very painstaking approach to do each adjustment.
(quoted from post at 17:59:52 09/07/16) If you still have my number give me a call again, I have trouble getting thru to you. I AM CERTAIN I can make it steer.. Just takes a very painstaking approach to do each adjustment.
Hi, I don't have your #. I 'm thinking that you are probably talking about adjusting the bearing lash on the bevel gear by removing the stationary brake shoe other than that we could not find what you were talking about.
