Help figuring out Davis Fleetline 30+4
Snype32
New User
Hello... new to the forums here and am hoping someone can help me out a bit. I have a very old Davis Fleetline 30+4 trencher. I am looking for some seals for the hydraulic pump, but cant figure out what year my unit is. Serial number is 3045, but I can't find anything on it.
Davis didn't build your hydraulic pump, and you don't need Davis info to get a seal for it. Post a photo of it, and, likely someone can help ID it, or research numbers you find on the pump on the 'net.
That being said, it MAY not be possible to reseal your pump and have it last.
If it's a typical little aluminum gear pump with some hours on it internal wear/leakage and shaft bushing wear will lead to a new seal not lasting very long.
Check out www.surpluscenter.com, they have a wide variety of new and new surplus pumps at good prices, and can often help you find a close replacement for yours.
(quoted from post at 21:07:45 08/24/16) Davis didn't build your hydraulic pump, and you don't need Davis info to get a seal for it. Post a photo of it, and, likely someone can help ID it, or research numbers you find on the pump on the 'net.
Thanks for the reply... I will do that. I would still like to get some further info on this unit though. It needs a few other parts that I can't find in any parts list as this 30+4 seems different than most for some reason.
What do you need I still have some parts laying around -- although that 1 is newer than the 1 I had. I will try to remember to check back here tomorrow. I don't have any pumps or seals.
