Oliver goes in circles
Rexkramer
I have been searching and searching for information on the
drive system in an Oliver oc6 and can't find anything. So what
would most likely break in one of these that would cause it to
loose power to 1 track? Is there anything common that
breaks? I know it's a vague question, but id like to be informed
before I go look at the machine.
Oc6 probably has track clutches. a failed clutch would cause the loss of drive. A coupler from track clutch to final, or from clutch to ring and pinion. If like an Oc3 it would not move at all. Jim
I believe those machines are differential steer, so a stuck brake would do just as you described
Contact Landis Zimmerman in Lancaster, PA. He has a website with a phone number and will tell you what to look for. He stocks parts also.
