d6b pony motor removal
tammie76
New User
Hi there dad and I are trying to remove a starting motor off a d6b 44a5732 cat we have removed the injection pump front mounting bracket magneto and oil filter but starting motor will not come loose
Have we missed something? Any help appreciated
Removing because it won't drive the big motor
Make sure you di't forget a water or oil line and am't sure but maybe he has a long bolt from bottom starting engine to the big motor
(quoted from post at 17:59:57 08/08/16) Make sure you di't forget a water or oil line and am't sure but maybe he has a long bolt from bottom starting engine to the big motor
All lines have been removed and we tried to pry ahead and upward with two bars and no movement checked top of bell housing and there r no bolts
Make sure the starting engine is in neutral angagement and check for a support bracket and he should have a long bolt cross the starting engine to the big motor
(quoted from post at 05:13:44 08/09/16) Make sure the starting engine is in neutral angagement and check for a support bracket and he should have a long bolt cross the starting engine to the big motor
That what we thought but nothing is visible
Do we have to remove the oil pan?
I could text you a pic......
