International TD6 Crawler parts
UK Crawler
New User
Hi my father is doing up a TD6 Crawler and the engine has seen better days, in the UK it's really hard to locate anyone who can help get parts for one... So I'm wondering if anyone state side can help point me in the right direction to a supplier in the states??? Below is the list of things he's looking for
International TD6 Crawler Serial No: TDBK 1419
4 pistons, rings and liners
complete set of engine gaskets top and bottom
crankshaft and bearings
clutch cover assembly
clutch plate
clutch thrust bearing
spigot flywheel bearing
2 cylinder head studs and nuts
timing gear (injection pump drive, American Bosh)
1 con rod
set big end lock tabs
oil pressure pipe from block to the gauge
oil filter
fuel filters
decal set
Hello, assuming this has the engine that starts on petrol and runs on diesel at least some of the parts you need should be available in North
America. To help your search the Farmall MD, Super MD etc used the same engine. On the downside it is very expensive to ever haul one of
those engines. Good luck, Sam
Just a heads up the parts your looking for are going to run you well over 6-7k US money. They are not cheap engines to work on and with that early of a serial number it probably has the bosch fuel system. I have 3 of these style diesels and they can be a nightmare. Sleeves and piston kits are getting pretty tough to get even over here. Good luck jim.
What is the serial number on the engine, it
is found behind injection pump just below
head gasket. Will start with prefix TDBKM.
That will be needed for aquiring engine
parts as there are serial number breaks with
those early engines, went thru it with my 41
md.
I live in Mid-Missouri and there is a salvage yard that specializes in Crawlers, has lots of INternational parts about 20 mi from me and I purchase parts for my T-6 from. It is Zimmerman Tractor, 13874 Hwy 5, Versailles, MO 65084, USA. The phone number is USA Area code 573-378-7210 website is www.crawlerbulldozer.com. My email is [email protected] if you need any additional info.
