UK Crawler
New User
Hi my father is doing up a TD6 Crawler and the engine has seen better days, in the UK it's really hard to locate anyone who can help get parts for one... So I'm wondering if anyone state side can help point me in the right direction to a supplier in the states??? Below is the list of things he's looking for
International TD6 Crawler Serial No: TDBK 1419
4 pistons, rings and liners
complete set of engine gaskets top and bottom
crankshaft and bearings
clutch cover assembly
clutch plate
clutch thrust bearing
spigot flywheel bearing
2 cylinder head studs and nuts
timing gear (injection pump drive, American Bosh)
1 con rod
set big end lock tabs
oil pressure pipe from block to the gauge
oil filter
fuel filters
decal set
clutch plate
1 con rod
oil filter
fuel filters
decal set
