1000 case is the same trans that is in the 800 & 1150 .
I have several 1000's , very tough tough trans. Loader
I have I bought in winter of 67,68 and have been in the
trans once ,reason is the teeth broke off on one of the
clutch discs. Worked on the finals several times, seals
and bearings.
It is an 8 clutch trans with 4 controlling each track
independently of the other , they are an absolute
pleasure to run.
george
George I have a fellow hunting a continental h260 diesel engine. Is that what the 1000 case dozer ran. If so do you have any engine parts?
The Case 1000 uses a continental " JD 382" 4 Cyl.
Diesel engine which is larger than the H 260.
Not sure how many if any parts interchange with the H260.
George will know.
Tom
JM,
Very little interchanges, 800 & 1000 case use the same
water pump which is totally different from MF tractors.
Need to look to see if some of the cam bearings swap.
I made cam brgs for 1000 from other cont'ls , used G series
rear , 2 f ser center for center with modifications .Have
to look to see what I used for front. Injector nozzles
are same ( 12 SD 12). i have part of an H model out back,
and I think with some imagination I can make 188 case mains
work , winter project.
For the 382 I bored and sleeved the sleeves because years
back there were no new ones , might have to do that for H
series.
Send me an email with # and I'll call you.
george
