1845 case skidloader Temp Guage
pinball
I have a bad temp gage on my 1845 case skid loader. Its the electrical type. Has anyone ever converted these to the long thermos couple. Not sure the thermos couple is good on my electric gage. no the gage is bad it self. I have found the thermos couple and wondered if it would be better to change it out. any thoughts out there. thanks norm
Why not just fix what you have. Should be less than 50 bucks for new gauge and sending unit. Can,t be much else unless th3 wiring itself is bad. Will take a long lead like 72 inches or so if you decide to go the other way. But yes depending on what engine you have will determine where you could locate the other unit.
the temp guage from case is 72.00. thermo couple is 50 bucks. total 122 dollars. case makes good equipment but boy are they proud of there parts. that's why I am looking for an alternative.
take the wire off of the sender and ground it,
turn key on momentarily
if gauge pegs it is ok, change sender
if not probably just the gauge
