Roger12356
New User
I have a 1970 Cat D6C non turbo dozer. Serial 10KXXXX I replaced the belts and the fan is blowing air through the radiator. When I push trees and light duty stuff it is fine. When I start hogging up dirt and really work it, it will warm up to the red. I can stop and idle for 3 minutes and it cools down where I can operate it again, for a while. It is never low on coolant. It does have the engine enclosures on the motor. Does anyone have experience with this problem? Should I remove the engine enclosures? I built a terrace late last fall. It was cool enough I had to wear coveralls and a heavy coat etc. I could work the heck out of it all day and it didn't heat up to the red. It has to be something minor I would think?
Thanks for any help
Thanks for any help
