Case 600/610 Crawler pics needed.
FredR
I am looking for close up pictures of the leaf spring pack on the undercarrage of a Case 600 or 610 Crawler. The machine I am restoring is missing both leaf springs and a picture would sure help to match something up if I have to go that route. If somebody out there can help me out that would be great! Thanks
FredR
Hi Fred,
I posted a picture over at Yahoo groups.
Let me try on here for you.
Tom
Perfect! I seen the other pic over at Yahoo groups as well. Thanks again!
Now to find a set........
Great!
You might try Schaffer Enterprises in IL.
http://www.sewlparts.com/
Last time I was there he had numerous Case Terra-Trac crawlers dismantled.
In fact I got a final drive from him.
Tom
go to a spring shop and they will make what you need. if your in WI can can tell you the place to go
Can I ask a big favor Tom? I was wondering if I could get some measurements from your machine. How wide are the springs. What are the dimentions of the bracket that holds the springs to the machine. Also there should be another piece to the bracket that sandwiches between the outer bracket and the plate.What are the
dimentions of it, if you can get in there to measure it. One other measurement would be the bottom plate that holds the U-bolts that bolt up through the bracket. With these measurements maybe I can fabricate a support bracket untill I can locate an original. If you can help me out that would be very much appreciated!
Thanks, Fred
If you have a email address I will send you a copy of page 84 and 85 out of the service manual for the 520.has all the size's and part #
Sent you one email and it was kicked back as to big. Divided it into three parts and resent. You should have received them but your email provider sent me a message on # 2 and 3 3 as you are over your limit for emails.
Will send the rest tomorrow. the one you got should be what you need today.
