I'm looking at a crane that has been sitting for years. The boom is presently extended and angled about 20 degrees, just enough to be about 13' total width, which is too wide to transport according to the trucker we called. So we have to get it to turn first.
Engine (detroit) starts and runs great. The outrigging and steering (front/back) works but slowly and sometimes jerky.
The boom controls do not work at all, no twitches, nada. Except that when I operated one of them (boom up) oil shot out of a open hole in the line near the base of the boom. We threaded a plug into that, no more leak. Anyway, that was proof of some pressure. After that, operating any of the boom controls gives zero response. no movement, no detectable noise from pump, hoses, valves. just seems dead.
In order to get the boom to swing we tried attaching a chain to it and dragging with a truck (with the swing control lever engaged) but it wouldn't budge at all.
Diagnosing.
There are two hydraulic pumps operating from a single tank. The smaller pump is belt driven and supplies the steering and outrigger controls. The larger pump is directly coupled to the engine and supplies the boom controls. Both pumps are fed by the same supply hose from the tank, with a Y in it.
As far as I can tell, both systems are independent after each pump, and back to the tank, but I could be mistaken about that. Assuming they are independent, I think it is a good sign that there was oil squirting out when I operated the one boom control, because that indicates the main pump must be doing something.
One theory is that there may be a clog somewhere, possibly a filter in the tank. That doesn't seem quite right though since the smaller pump is functioning (albeit slowly). I would expect the controls on the larger system to at least twitch.
I guess it could be either the main controls or the main pump.
I'm not a hydraulics expert so not sure what to check next. advice appreciated.
Also anyone know about these old austin western cranes and can explain the hydraulic system? where filters are and how to change them?
Diagnosing.
