Tracy Brown
I just bought this machine for home use. It has a couple of issues I need to address before use. It had been setting a few years and would not
start. The PO had the injector pump rebuilt and now it starts and runs good. I have not run it very long at a time but noticed it starts to overheat.
There is no water/oil mixing anywhere. I removed the thermostat. No change. My next thoughts were water pump and or radiator, but if the
timing on the injector pump was not done exactly right, can that effect operating temp? I know it can on a gas engine. It has a Mitsubishi 4D30
engine. I believe this entire machine is Mitsubishi. Some of you experts, where would you look next. Thanks
