Dresser TD7H enclosed cab wanted
JFoshee
I might be interested in swapping my open rops to an enclosed cab if I could find one. I did some research tonight but had no luck. Anyone have an idea where I might get a price on one?
You have several things working against you.. First of all just not that many H models of the 7/8 sold. Many less sold with cab and then third those that were are still running. You could use one for a 8h also it will fit. What are you going to do about air-conditioner. Without it that cab is almost unbearable. Try Blount parts in Hoboken Ga. if anybody knows of won Tim might.
I knew it was a needle in a haystack kind of deal, but I thought I'd try. As for the A/C I was thinking of maybe an aftermarket deal to mount on the rear of the cab. It may not work. I 'm just spitballing right now to see if it's a possibility. Thanks for the hook up. I'll give them a try.
Cover the top of your rops for shade and you will be much happier. Older cabs are hot and noisy, unless you are using it mostly in winter it will be awful
