MF 200 Crawler with transmission problem
Norman S.
New User
I have a MF 200 crawler. The problem I am having is the crawler won't move. I don't know if the problem is in the hydralic reverser. The machine runs great and the blade works good. Does anybody have a idea of what's wrong and where you can get parts. Thank you.
Norm you can check all the oil you want but one place that you should check has no dip stick and it's to hard and to long to type a post on it so just call me and i will walk you trought it.
Thanks for your reply and phone#. If the weather works with me tomorrow, I'd like to give you a call while I'm "in front" of the dozer.
Thanks again,
Norman
Marlowe, I'm also having a problem with a 200 dozer that it stops pushing after 20-30 mins of operation. Would you mind if I give you a call?
High I am Robert My 200 crawler massy ferguson stops pushing after about 20 or 30 minutes will not go forward or backwards dose any out their have any ideal on what I should do ? after it quits crawling wait about 10 minutes and then you can start pushing again , I am lost on what to do all help is appreciated .
(quoted from post at 19:50:03 02/19/10) give me a call 9208517182 easyer to talk to you the type up till 10 cst
I saw your post and was wondering if I could give you a callk also. I'm working on an mf 200 and am having transmission problems also. Hydraulic reverser trans only wants to go in reverse and not forward. thanks paul 7167967913 text EST
Welcome to the forum.
Good luck on this. It doesn't look like he has posted for quite a while. A search for his latest post, using his name, shows it was in July of 2010.
Due to the fact that this site uses two different views (Classic and Modern) anyone viewing thread this using classic will only see what you just posted. Kind of a disjointed rambling in space. The best advice here is for you to start a new post of your own. Describe your machine, layout your problem(s), and what testing/diagnosis, maintenance, or repairs you have done trying to correct the problem. There are occasional questions here on the MF dozers so you will likely get some response, but it might not be immediate so hang in there.
Do you have the manuals for it?
