Old CASE 530 Construction King loader tractor from 1964 has the model 32s loader with a PARKER Hannifin 2 handle control valve. I recently replaced all the lines, drained and installed new fluid and bled all the air out. Valve assembly does not leak and loader holds solid with a load after shut off.
The action is smooth on both lift and tilt but very slow and lots of rpms needed with no load or full load. It was a little faster prior to the clean up but still real slow. It is full and no leaks.
Does the valve assembly allow for adjustment normally? I see the hand adjustment knob on the rear of the valve but do not seem to get any difference in speed. Appreciate any experience with the old iron setup.
