Case o matic
ffreeb
I have a 530ck. Coming home with it I pushed in the clutch pedal to shift it and after that the drive started slipping. It worked good before. The pressure gauge on the dash is almost 0 with the pedal up or down. The pressure at the filter is 170. Any ideas where to look or where to check pressure next?
Trace the linkage from the pedal you pressed when it lost drive,it may be the linkage is sticking and holding the valve open,the linkage should be moving freely.
AJ
I have seen them do that and it is the oil pressure regulator spool sticking, it is Next to the control valve where the clutch spool and com spool, item #1 on the link provided
cnt
parts link
I hope this might help someone else. I pulled off the dump valve,
clutch valve, and found a piece of silicone in an orfice. Cleaned
that out and it's back to normal.
