Calgary Glenn
New User
Hello, I have a 9550 on a 350C crawler loader, My problem is the control valve for Left/Right swing sticks and I have to wiggle the level to find neutral.
When I got the unit I drained the hyd system, it was very dirty with crud from condensation. I cleaned the tank, filled with cheap hyd fluid and ran it and drained again and filled with JD fluid.
I am wondering if there could be crud suck in valve and how to clean it out.
If I have to replace valve does any one know if I could use a valve fron a 310/410? The JD online parts books are not clear. I may have luck finding a used value if I could identify which one it is.
Anyone's ideas for a soultion would be great
