My old 64 Case 530 CK loader tractor has the model 32 loader and a big counterweight on the back but I do not know if it originally also had a backhoe.
I see in the 32 service manual only the right side of the loader frame gets filled with hydraulic fluid IF the unit is a loader and both sides if it has a hoe. several gallon difference. Mine has the hydraulic tube running from the bottom of the left loader frame (tank) as well as the right.
Does the hydraulic fluid still flow into both....just less or should the left side not be involved at all with only a loader? Seems to me the tube either indicates it had a hoe at one point or I am missing how the fluid level works (probable!) and I will always be overfilling..... Once I fill only the right side with the correct amount up to the fill level, it seems the running of the unit would transfer fluid to the left tank as well to equalize level because of the tube and the right side would indicate low?
Should the left side not have the tube running to it? I sure appreciate any experienced info. My 69 580 CK has the hoe and loader so it is different and I can't use it to reference.
Thank You
Thank You
