58oB injector pump swap
Keith Molden
Just wondering if an injector pump off a 580B will work on a 580 CK. It appears that the horsepower is different but both have the 188 diesel engine in them. A friend has them and wants me to help him swap them out. I really don't know if they are the same. Thanks in advance. Keith
Looked up the part numbers of the pumps and they differ,as far as I can make out it is only the RPM setting that differs,the pumps will fit.I would swap them and adjust the RPM to suit,to make it easy take off the timing window of the pumps,turn the engines till the match marks in the pumps line up,swap the pumps with no need to bother the timing,match the marks again,do not turn the engines with the pumps off.
AJ
