Help identifing this crawler
pinball
Can someone tell me what this is. I think its a terratrac . if so wll the tracks from a case 310 work on it . thanks norm
It started out as a TerraTrac but has been heavily butchered since.
On the left side top of frame by the starter the SN # and model # is stamped.
Unless that's gone too.
Can't help with the tracks until you find out for sure
What it is.
I'm going to guess a GT 25,28,or 30 probably.
Tom
This dozer only has two undercarriage rollers on each side. Never seen one with out at least 4. tracks are really bad. continential 4 cylinder motor. rear sprockets don't look to bad. front idlers aren't welded up. number on starter is MZ4156. 3 SPEED TRAnny.
Does yours have holes for the other rollers? Yours has the later spoked rear sprockets. ATC Terratrac's were built in Churubusco Indiana 1950 to 1957 then Case bought the company. Before 1950 they were built by Federal Machine in Ohio as the USTRAC.
(quoted from post at 13:06:57 04/16/16) This dozer only has two undercarriage rollers on each side. Never seen one with out at least 4. tracks are really bad. continential 4 cylinder motor. rear sprockets don't look to bad. front idlers aren't welded up. number on starter is MZ4156. 3 SPEED TRAnny.
Looks like it started out as a GT34 TerraTrac.
That is definitely a TerraTrac track frame ,sprockets, and engine
Compartment.
Could you locate the stamped numbers on the frame by the starter?
Not starter numbers.
Tom
Best name for that crawler would be MONEY PIT, If they give it too you still want be cheap enough.
Maybe a WORN OUT" brand?
There is a bloke who has been posting an extensive series on rebuilding a Terratrack over at Red Popwer. I don't have a link.
After asking questions and seeing how bad the tracks were, upper rollers missing as well as some underneath, starter wont turn the motor over ( motor is free ) just cant see the $1100 he is asking for it. I have an early 310 parts machine that I think some of the parts will work but just don't think it will be worth that much if I did get it to where it can be used. So ill keep on looking.
FYI
Here is the link to the Terratrack restoration over at Red Power
http://www.redpowermagazine.com/forums/topic/83591-1952-atc-terratrac-gt30-track-loader-roller-repair/
This bloke has done an awful lot of work shows in the 23 pages!
