Mr. T. Minnesota
Forum,
Previous owner of HD3 Allis crawler welded both ends of the master pin on one of the tracks. Question is can I drill into the master pin? Plan to use a 1.25 inch hole drill to cut into the welded surface of the 1.25 inch pin end. I do not have access to a torch which would make it an easier task. Any and all thoughts are welcome. Reason for this question is the crawler is four hours away and need to have all options covered.
Mr. T. Minnesota
Mr. T. Minnesota
