working on my 1280 case excavator to get the new final drive shaft back in and new pillow block bearings on.question,book shows 23 teeth on the drive sprocket and mine has 21.always noticed it would creep on one side when running it before it broke but not real bad,if the other side has the original sprocket of 23 teeth on it(real hard to count as it is covered with guards and shields)Is it going to be hard on the separate drive motors if I put the old one back?There is not another one available in the whole world as I have exhausted 3 days of looking for one!!Also going to broach in a 1/2 inch keeyway since the center of the splines is ground up,will one keyway work if we build up the wore area and machine it down?will welding up the shaft and milling it back cause the weaking of the shaft?Thankyou guys,your the best!!Dave A
