Cat D2 $500 on Craigslist
What's so rough about the tracks other than needing adjusting? Looks like good sprockets and serviceable grousers, really can't see the rail well enough to judge
Looks like the drive sprocket has been changed at some time. If the didn't turn or replace the pins, that sprocket won't last long. The rails are worn quite bad; notice that some are worn slightly wedge shape, which points to a costly repair. My guess is that the track adjustment is probably all the way out. Grousers are so-so. I would price out a track job before I made an offer on that one. Then check out the engine and transmission; sometimes they have a tooth missing in some gear. The D4 that my brother has, has a chipped 3rd gear - and you can hear it if you use 3rd.
seller states ran when parked a year ago and frozen steering clutch and bad brake---still waiting for him to get serial #
