As posted I have a 580 SK that will not crank. The battery is hot and I can short the starter and it cranks just fine. I assumed the neutral start switch was bad so without checking anything I replaced it. To my surprise it didn't fix anything. I have checked under the unit and no connectors appear to be unplugged or wires rubbed into. It went from cranking perfect to nothing. It was running in a yard with no underbrush or debris to hang something when this happened.
Lastly, I can hear what seams like a relay clicking under the dash when the switch is turned to the start position. I have not checked anything else yet except for the switch, which is good. Some help on what to check next or a wiring schematic for this unit would be great.
This is all I know right now. Any help would be appreciated.
