Alright, yes, I know I've got an obsolete duck here, and that's why I have the question I have. I have an '85 Fiat-Allis 8B dozer, 5600 hrs, at some point the rails/grousers have been replaced. One sprocket had been replaced just before I got it, and the previous owner sent the other new one with the machine. All parts look good, but what I don't get is the track with the new sprocket can be tensioned correctly with about half the travel left in the tensioner.. but the other is still way too slack with the adjuster all the way out. This sprocket is not worn badly either, but will replace it anyway since I have it. Undercarriage parts for these are like bigfoot, no one seems to have ever seen them, at least in the last 15 years or so. The rails are an odd metric pitch unmatched to anything out there that I've found. I don't have a pin press, nor do I want to buy a $1500 one or pay a service truck fee of 2-3K to do the work. I want to take a link out, and shorten the slack track and put the new sprocket on. Cutting the pins out would be no problem with a torch, but I can't get new pins for it, either. Someone suggested I cut two links in half, and then weld the front half of one to the rear half of the next, thereby losing the length of a full one, stating the track pad bolts will hold the most of it, and the weld will just be extra reinforcement. Anyone shorted one before without the "proper" tools to do so? Keep in mind, this is a farm dozer with only probably 100-150 hrs use per year.
