ratskinner
I have a John Deere 40 C that have replace both clutch packs I have the machine back together and both steering clutches are slipping I have adjusted the throwout bearing has back as far as it will go. I I think that the fingers on the pressure plate need to be adjusted for it looks like it is still touching the throwout bearing a little. What would be the best way to do this or is there something else I am overlooking. And some additional information would be when it was up on the jack stands and the tracks off both sides work perfectly now that the tracks on the ground it does not work
