Hello, have some questions about my "new" TD15 series 151 - 1961 model i believe. If I am correct, it share many items with the TD 14.
I have the operaters manual and service manual. after ?? years of sitting we got it running and it would turmn left and right so I bought it.
it has never turned left like it should, feel like brakes are worn on the left. I have adjusted those per the manual.
thinking that it could also be the left steering clutch was no disengageing completely I went through the procedure for that too.
After all that the left steering lever pulls all the way back to the seat with the motor off or on. The right one feels normal - but does not disengage the steering clutch now. My tank is full of hyd. fluid
info on these is VERY hard to find. do i need to bleed the hyd steering system ? How ?
Can I remove the hyd steering system and just convert it to manual steering? i expect I could loop the pump line for the steering back to the pump ?
thanks for any help or ideas. it's currently not driveable : (
