I have a 1975 allis challmers 715D backhoe/loader with a 65HP perkins diesel. Was using the hoe for plowing snow and all was working well. On the drive back to the barn I noticed that I had to continue working the steering wheel in one direction to just keep the tractor going straight. The next day when I tried to go out and plow roads I had no power steering. Temps were down to mid teens so I thought it was moisture in the hyd. oil that had froze in the lines or valves. That wasnt it, next I pulled the bypass/relief valve assembly to make sure it was operational and all seemed fine. I wasn't sure I had enough hyd fluid in the tank so I added an additional 5 gallons which brought the level up to within 4 to 5 inches from the fill spout.
All the rest of the hydraulic functions work fine....any ideas would be appreciated.
My next try is to see if I can prime the power steering pump from the pressure side where the hoses go to feed the steering wheel motor. Would that work if I lost my prime and cant get it to reprime? Do I need to bleed out air in the pressure lines up by the steering hyd. motor?
