This message is a reply to an archived post by AJ. on February 02, 2011 at 18:20:13.
The original subject was "Re: Case 580B Backhoe".
580b manual that was available .pdf posted in 2011. Do you still have that available. I just picked up a 580B to use around the yard. The machine is slow to move. It has a 4 speed shifter on the floor and a forward-N-reverse lever on the left of the column. 1-2 it moves slow and in 3-4 it tries but doesn't have the power. I have to check fluids and filters, but I wanted to get some information on the drive and hydraulic circuits. I also need to work on the lighting and electrical circuits in the cab. The machine was a rental at one point. Has a rebuilt engine. good rubber. 2wd. needs some pin and bushing work. Missing the boom/main lock mechanism but otherwise looks good. Any information would be appreciated. Thanks,
Christopher
Christopher
