Cat d3b s#23y0434 steering yoke stop bolt adj
Pogo3
New User
Just wandering if anyone could give me the specs on how and what the stop bolts are to be adjusted to?
My D3B manual shows to move the piston out to a distance of 1 inch then adjust rod so it contacts the yoke.
then adjust stop bolt to a dimension of .315 inches clearance to steering clutch housing.
(quoted from post at 06:38:29 12/31/15) My D3B manual shows to move the piston out to a distance of 1 inch then adjust rod so it contacts the yoke.
Thanks for the info. This sight has really gave me a lot of help with the removal of the steering clutches so I could remove the bevel gear and adjust the brakes on the d3b this is the first dozer I have ever owned and it seems who ever had it before has got all the linkages for the steering and brakes all out of adjustment so just wanted to give a big thanks for all the info.
