Johnredpwr
New User
I am working on an ru-d6 that has been parked in the hills for 10 years.I did start it twice but found problems and had to fix them.
Now for some reason I can not get the engine to start before it throws out the pinion gear.
I did realize after the fact I have the pony motor revved up can that be the problem.Maybe its going to fast and when the motor starts to pick up it has to much centrifugal force and throws out the pinion gear ??
engine turning under compression it has white exhaust then when I add fuel it go's black so it's getting fuel even thou the fuel gauge is not working .I did bleed the injectors they all are squirting fuel.
I can use any tips or info
thanks John
thanks John
